Our customer needs a replacement for NXP PTN3700 RGB-to-LVDS video interface link.
FROM CUSTOMER:
Needs a video bridge that can take 6bit each of R,G,B and put out LVDS that looks like:
The data rate on the LVDS isn’t much…like < 40MHz.
Looks like Articlinc III has a device for this function.
https://www.quicklogic.com/products/dis ... clink-iii/
RGB-to-LVDS part number is: CSSP-BPFDN120
Is this device the right one to consider? Is it programmed by Quicklogic? What is the availability?
Replacement for NXP PTN3700
Yes, the Bx5A1D is the right device for this application, it can bridge between your RGB interface and the LVDS display.
The full datasheet for the 2 channel LVDS device is available at https://www.quicklogic.com/wp-content/u ... _Sheet.pdf
Here is a concise answer (in English) to your customer’s questions:
The part CSSP‑BPFDN120 from QuickLogic was listed in the same family as their display-bridge devices that convert RGB or MIPI input to LVDS output.
QuickLogic
+2
QuickLogic
+2
BUT according to QuickLogic’s “Product Change Notification,” CSSP-BPFDN120 is now obsolete — last-order date was 09/30/2024.
QuickLogic
The more relevant current device family is CSSP‑BXFDN120 (part of the ArcticLink III BX display-bridge family). That device is described explicitly as bridging RGB inputs to LVDS (single or dual link).
QuickLogic
+2
FPGAkey
+2
Configuration of ArcticLink III bridge (RGB → LVDS) is done via I2C/SPI registers — i.e. it’s “programmed” via register configuration, not user-FPGA programming.
QuickLogic
+1
CSSP-BPFDN120 is not a good choice today, because it is obsolete / end-of-life. Instead, consider CSSP-BXFDN120 (ArcticLink III BX) for a RGB-to-LVDS bridge. It supports RGB input and LVDS output, and is configured via registers, not custom programming play plants vs brainrots
QuickLogic
+2
QuickLogic
+2
QuickLogic
QuickLogic
+2
FPGAkey
+2
QuickLogic
+1
alexreynolds
The part CSSP-BPFDN120 from QuickLogic was previously listed in the same family as their display-bridge devices that convert RGB or MIPI input to LVDS output. However, according to QuickLogic's Product Change Notification, the CSSP-BPFDN120 is now obsolete, with the last order date being 09/30/2024.Robert wrote: ↑Thu Jan 18, 2024 11:39 pm Yes, the Bx5A1D is the right device for this application, it can bridge between your RGB interface and the LVDS display.
The full datasheet for the 2 channel LVDS device is available at https://www.quicklogic.com/wp-content/u ... _Sheet.pdf quordle
The more relevant current device family is the CSSP-BXFDN120, which is part of the ArcticLink III BX display-bridge family. This device explicitly bridges RGB inputs to LVDS (single or dual link).
Configuration of the ArcticLink III bridge (RGB → LVDS) is achieved via I2C/SPI registers; it is programmed through register configuration rather than user-FPGA programming.
The CSSP-BPFDN120 from QuickLogic was previously categorized within the same family as their display-bridge devices that convert RGB or MIPI inputs to LVDS outputs. However, based on a Product Change Notification from QuickLogic, this part is now obsolete, with the final order date having been September 30, 2024.
The currently relevant device is the CSSP-BXFDN120, which belongs to the ArcticLink III BX display-bridge family. This device is specifically designed to bridge RGB input signals to LVDS output, supporting both single-link and dual-link configurations.
For the ArcticLink III bridge (RGB → LVDS), configuration is handled through I2C or SPI register settings. The device operates via register-based configuration rather than requiring user FPGA programming.
