QL4009-1PF100C - Part Marking difference
Posted: Fri Sep 08, 2023 10:02 am
by BillLedgerwood
Hi, Please see attached image of this QuickRAM chip. It does not state the PN family on the marking as I have seen before. It looks like this is a custom made part for Tandberg. Can I get confirmation that this part does not deviate from form fit or function on the datasheet specifications? Will there be any technical differences that will affect the performance in relation to the standard QL4009-1PF100C?
Thank you in advance!
Re: QL4009-1PF100C - Part Marking difference
Posted: Fri Jan 19, 2024 3:33 pm
Sorry for the delayed reply, I would need to check the date code marking to see if we still have record as this device.
It would appear at first glance to have a date code of week 5 2002. The QL4009-1PF100C is a ViaLink device which is one time programmable.
As this has custom marking I would suggest that it has already been programmed and can't be erased.
We have seen a lot of this on the grey market, so we can't guarantee the functionality or reliability of these devices, and I would be careful about purchasing them.
Posted: Thu Jul 04, 2024 3:06 am
by elijahnelson
In most cases, custom parts like this are not expected to have technical differences that would impact performance compared to the standard QL4009-1PF100C.
mapquest
Posted: Mon Aug 05, 2024 9:32 am
by felixandrea
Maybe some of these suggestions can help you:
1. Verify origin and validity: Since this is likely a custom part for Tandberg and may have been programmed once, verifying the chip's origin is important. Please contact the manufacturer or an authorized QuickLogic dealer directly to confirm the validity of this device.
2. Check the date code and identification marks: Provide complete information about the date code and any other identification marks on the chip to the manufacturer so they can inspect and verify the device.
rice purity score
3. Reviews from reputable vendors: Avoid purchasing devices from the gray market as there may be risks to functionality and reliability. Make sure you buy from a reputable supplier or from authorized sources.
4. Comparison with standard specifications: If possible, ask the supplier or manufacturer to provide detailed technical documentation of this custom chip for comparison with the QL4009-1PF100C standard. This will help you identify any differences in form, size, or function.
Wishing you success in verifying and using this device effectively!
Posted: Sat Sep 14, 2024 4:56 am
by EdwinLBetancourt
My opinion is that the forum post on "QL4009-1PF100C - Part Marking difference" highlights an important issue regarding the differences in how components are marked. This post not only provides useful information about a particular product but also warns of possible risks.
Posted: Fri Mar 21, 2025 10:05 am
by JolieKeva
Robert wrote: ↑Fri Jan 19, 2024 3:33 pm
head soccer
Thank you very much for all your work and this fix, keep up the good work!
Posted: Wed Jul 16, 2025 9:06 am
by starfish12
If the chip was custom-labeled for Tandberg, it may still be a standard QL4009 die relabeled for contractual or inventory reasons.
Posted: Sat Jan 03, 2026 3:08 pm
by Driving
Marking differences like this are usually customer-specific or lot-specific and don’t imply functional changes. Unless the manufacturer confirms otherwise, custom
mapquest driving directions markings typically follow the same datasheet specs for form, fit, and function. Performance should match the standard QL4009-1PF100C, but official vendor confirmation is always the safest route.
