Voltage level on the Output Pin
Posted: Wed Jan 13, 2021 2:28 am
by gunmin0826
Hello, what is the voltage level of the logical HIGH at the I/O output?
The datasheets "QuickLogic EOS S3 Ultra Low Power multicore MCU datasheet - Version 3.3d" and "QuickLogic EOSTM S3 Sensor Processing Platform Input/Output Multiplexor (IOMUX) User Guide Rev 1.1" do not provide information on this.
Re: Voltage level on the Output Pin
Posted: Wed Jan 13, 2021 4:39 pm
by anthony-ql
There are two banks of IO on the EOS S3. The supplies for the IO is named as VCCIOA and VCCIOB (1.8V - 3.3V). The logical "1" for input signal is 0.65 * supplied voltage. Logical "0" for input is 06v (max). Hope this helps.
Posted: Tue Jun 25, 2024 2:25 am
by Essa Mattou
anthony-ql wrote: ↑Wed Jan 13, 2021 4:39 pm There are two banks of IO on the EOS S3. The supplies for the IO is named as VCCIOA and VCCIOB (1.8V - 3.3V). The logical "1" for input signal is 0.65 * supplied voltage. Logical "0" for input is 06v (max). Hope this helps.
Very helpful! I tried it and it's perfect. Thank you!
