Posted: Tue Jun 17, 2025 1:21 pm
by marbu
Hey,
I would like to know if
Thank you!
Re: How to use EOS in Companion Mode (with external host processor)
Posted: Tue Dec 09, 2025 3:55 am
by plowhank
level devil
Posted: Thu Jan 22, 2026 1:53 am
by AnnJennings
Posted: Thu Jan 29, 2026 7:21 am
by alehyha
Posted: Wed Mar 25, 2026 10:39 am
by marryhile1208
alehyha wrote: ↑Thu Jan 29, 2026 7:21 am In Companion Mode, the EOS is typically booted by an external host. In this case, the firmware must be loaded via the SPI slave interface on every power-up, as the EOS does not automatically boot a persistent image by itself.
THANKS
Posted: Thu May 14, 2026 8:57 am
by George436
Companion Mode can be a bit confusing from the manual alone, so clearer documentation and a practical boot/loading example from an external host processor would definitely help developers working with EOS.
Posted: Sat Jul 25, 2026 9:15 am
by Alfieolloway
I ran into this exact hurdle when integrating the EOS S3 with an external MCU. Because the EOS relies on volatile SRAM, loading the firmware over SPI Slave on every cold boot is mandatory unless you switch to Standalone mode using an external SPI Flash. For practical implementation, I found QuickLogic's open-source qorc-sdk on GitHub far more useful than the reference manual for code examples and boot protocol sequences.
Posted: Wed Aug 19, 2026 7:28 am
by Carpentery
That's a tricky one! System startup with an external host processor can definitely be a maze, and the sparse documentation doesn't help. I've encountered similar issues when trying to optimize boot sequences. Have you tried looking for community-made examples or forums dedicated to advanced embedded topics? Sometimes the best insights come from fellow developers. It reminds me of the strategic thinking you need in games like Slither io to get ahead!"
Posted: Mon Sep 28, 2026 4:53 am
by alexandernevis
Thank you for bringing up the topic of Companion Mode and its integration with an external host processor. It would be great to clarify whether loading the firmware via the SPI Slave interface is essential on every boot cycle or if there are alternative boot modes available. Additionally, I'm also interested in any further documentation or examples related to flashing the EOS from the host processor.
Drive Mad
