Hey,
I would like to know if
Thank you!
level devil
level devil
AnnJennings
marryhile1208
THANKSalehyha wrote: ↑Thu Jan 29, 2026 7:21 am In Companion Mode, the EOS is typically booted by an external host. In this case, the firmware must be loaded via the SPI slave interface on every power-up, as the EOS does not automatically boot a persistent image by itself.
