Hey,
I would like to know if
Thank you!
level devil
level devil
AnnJennings
Despite its simple controls, monkey mart offers surprisingly deep idle management systems that reward smart planning and efficient store organization.
marryhile1208
THANKSalehyha wrote: ↑Thu Jan 29, 2026 7:21 am In Companion Mode, the EOS is typically booted by an external host. In this case, the firmware must be loaded via the SPI slave interface on every power-up, as the EOS does not automatically boot a persistent image by itself.
Companion Mode can be a bit confusing from the manual alone, so clearer documentation and a practical boot/loading example from an external host processor would definitely help developers working with EOS.
Alfieolloway
I ran into this exact hurdle when integrating the EOS S3 with an external MCU. Because the EOS relies on volatile SRAM, loading the firmware over SPI Slave on every cold boot is mandatory unless you switch to Standalone mode using an external SPI Flash. For practical implementation, I found QuickLogic's open-source qorc-sdk on GitHub far more useful than the reference manual for code examples and boot protocol sequences.
The Cps Test proves that online entertainment doesn't always need impressive graphics or complicated mechanics.
That's a tricky one! System startup with an external host processor can definitely be a maze, and the sparse documentation doesn't help. I've encountered similar issues when trying to optimize boot sequences. Have you tried looking for community-made examples or forums dedicated to advanced embedded topics? Sometimes the best insights come from fellow developers. It reminds me of the strategic thinking you need in games like Slither io to get ahead!"
ryanwhitacker
One practical detail that trips people up: in Companion Mode the S3 has no persistent image of its own, so the host must push the firmware over SPI slave on every cold boot. What you can avoid is re-pushing it on every wake — if you keep the EOS in a retention state instead of fully powering it down, the M4 SRAM contents survive and you only need the initial load. That is usually the difference between a 200 ms and a sub-10 ms resume on the host side.
Two things worth checking in your bring-up:
1. Hold the host SPI clock at or below 20 MHz for the first load. The QLSPI slave will ACK faster rates, but a partial/garbled image often shows up later as a silent hang in the sensor task rather than an obvious load failure.
2. After the load completes, poll the device status register before you start streaming sensor data. Sending the first packet while the M4 is still in reset is the most common cause of the boot working sometimes.
For examples, the QORC SDK repository is the most useful reference. The qf_helloworldsw and qf_ssi_ai_app projects both go through the host-load path end to end, and reading the linker script there answers most of the questions the reference manual leaves open.
Ryan Whitacker — ad performance tooling at Nereo
alexandernevis
Thank you for bringing up the topic of Companion Mode and its integration with an external host processor. It would be great to clarify whether loading the firmware via the SPI Slave interface is essential on every boot cycle or if there are alternative boot modes available. Additionally, I'm also interested in any further documentation or examples related to flashing the EOS from the host processor.
Drive Mad
Drive Mad
