Just to play with new platform, I bought a "Thing Plus – QuickLogic EOS S3". As soon as it arrived, I connected it to my SWD debugger and tried to enumerate it.
As intended by ARM debug infrastructure, it enumerates well, but there are a few overlooks (implementation bugs) that could probably be fixed in future HW revisions:
- DP IDR is 0x2ba01477, which means it implements DPv1 (See IHI0031G B2.2.5), this is perfectly valid, then target identification should be done through Base ROM Table (See ARM IHI0031G D1.3.1),
- Nonetheless, SW-DP TargetID register (Bank 2, address 0x4) is implemented and contains 0xf0000041, which decodes to STMicro's Jedec ID (Cont=0, ID=0x20, i.e. idcode[11:0]=0x041) (but quite close to V3 semi's ID (Cont=1, ID=0x41, i.e. idcode[11:0]=0x183) (bug ? see below)),
- Base ROM Table (the one at 0xe00ff000) is supposed to contain a PID matching the target device. It contains PID=00000004000bb4c4. This is an ARM identifier (probably the default in CM4 source code), but there should have been a QuickLogic ID there.
Now the questions I could not answer with the TRM:
- Is there a SoC ID somewhere in a read-only memory-readable region that could confirm this is an EOS-S3 chip that i'm actually talking to ?
- Is there a "Die-ID" or other per-instance unique ID register mapped somewhere ? Maybe in fuses ?
